PPTP 742 Error
Jun 23rd, 2010
I have a 831 router with the c831-k9o3y6-mz.123-2.XC2.bin software image.  I have set the router to accept incoming PPTP tunnels which works fine with Windows XP workstations.  When I try to connect via a Vista or Windows 7 machine I get to "Registering your computer on the network..." and it fails with "Error 742: The remote computer does not support the required data encryption type."
I have the following commands...
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
interface Virtual-Template1
ip unnumbered Ethernet1
peer default ip address pool VPNUSERS
no keepalive
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
Any help would be greatly appreciated.
Federico Coto F... Thu, 06/24/2010 - 07:12
  • Green, 3000 points or more
The router is requiring MPPE encryption from the PPTP client.
Is MPPE encryption enabled on the vista/7 machines?
Could you try setting the encryption to optional instead than required and see if those machines connect fine?
Federico.
TODD BENNETT Mon, 06/28/2010 - 07:04
I will try your suggestion.  I'm not sure how to check to see if MPPE is enabled on a Vista / Win 7 machine.  Do you?
Thanks again for your help.
Todd
