VG224 BAT
Answered Question
Jun 23rd, 2010
Hi All,
I am using CUCM 7.1. In order to add VG224 MGCP by BAT, it says enter the first 10 digits from MAC address. what mac address is it referring to?
thanks
ALex
Correct Answer by Aaron Harrison about 6 years 9 months ago
Put the name that you will configure the VG224 with, e.g. when you configure it (yep, you do need to put basic config on their - IP, mgcp commands, config download etc) you will set the hostname and optionally ip domain name:
hostname VG224-HeadOffice
ip domain-name mycompany.com
In that example your device name would be:
VG224-HeadOffice.mycompany.com
You may not set a DNS domain name, in which case the device name would be
VG224-HeadOffice
It is important that it matches exactly, if it's not right it won't register.
Finally, if you use DHCP it might pick up a domain name from DHCP even if you don't expect it - generally you'd use static addressing for this sort of thing though.
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 06/23/2010 - 15:11
  • Community Spotlight Award,
    Member's Choice, May 2015
The MAC address of the LAN interface on the VG224 that you will bind the protocol to...
Do you mean SCCP?
MGCP would register by 'domain name' (i.e. hostname + dns domain name as configured on the VG224), not by MAC addres...
Aaron
Please rate helpful posts...
alex goshtaei Wed, 06/23/2010 - 15:15
thanks for the reply,
it's MGCP, so what do I have to put in "MAC Address / Device Name" column in BAT file?
thanks again
Alex
Correct Answer
Aaron Harrison Wed, 06/23/2010 - 15:24
VG224-HeadOffice
Aaron
