Dial peer preference never makes it to 3 get Recovery on timer expiry
Jun 23rd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
Doing some CME-as-SRST testing, so I pulled the WAN link now when I dial a number on the router’s PRI I get a “Recovery on timer expiry” as it tries down the dial peers the first two will fails since the Sub/Pub aren’t local.  Any thoughts, the T.310 timer didn’t help. I can pickup a phone and dial 42104060 and it works, it just a dial peer timeout issue I can’t remember how to fix -jason
Dial 281-647-1100 in SRST rings 42104060 which matches dial peers;
First dial peer is Subscriber
Second dial peer is Publisher
Third dial peer is CME-as-SRST with a .aef script
dial-peer voice 42104060 voip
description **UCCX 800-422-4060**
preference 1
destination-pattern 42104060
session target ipv4:10.225.55.133
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 42104061 voip
preference 2
session target ipv4:10.225.55.132
codec g711ulaw
no vad
dial-peer voice 42104063 voip
description **cue autoattendant pilot number**
preference 3
session protocol sipv2
session target ipv4:10.225.106.3
dtmf-relay sip-notify
codec g711ulaw
no vad
debug isdn q931 is              ON.
Router#debug voip ccapi inout
voip ccapi inout debugging is on
Router#
Jun 23 20:47:19 dst: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x00DF
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
                Protocol Profile =  Networking Extensions
                0xA10F02010106072A8648CE1500040A0100
                Component = Invoke component
                        Invoke Id = 1
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '9043383245'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '1100'
                Plan:Unknown, Type:Unknown
Jun 23 20:47:19 dst: ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0x80DF callID = 0x00C0 switch = primary-ni interface = User
Jun 23 20:47:19 dst: //-1/42445AFA80A9/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=9043383245
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=42101100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 23 20:47:19 dst: //-1/42445AFA80A9/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x491ABDB0, Call Info(
   Calling Number=9043383245,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=42101100(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jun 23 20:47:19 dst: //-1/42445AFA80A9/CCAPI/ccCheckClipClir:
   In: Calling Number=9043383245(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=9043383245(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Jun 23 20:47:19 dst: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 23 20:47:19 dst: :cc_get_feature_vsa malloc success
Jun 23 20:47:19 dst:  cc_get_feature_vsa count is 1
Jun 23 20:47:19 dst: :FEATURE_VSA attributes are: feature_name:0,feature_time:1253757960,feature_id:769
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
  Call Info(Calling Number=9043383245(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=42101100(TON=Unknown, NPI=Unknown))
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/cc_process_call_setup_ind:
   Event=0x4823FC98
Jun 23 20:47:19 dst: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 42101100
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccCallSetContext:
   Context=0x4A5AC4DC
   >>>>CCAPI handed cid 749 with tag 10 to app "_ManagedAppProcess_Default"
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=42104060, Params=0x4A5A8BCC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccCheckClipClir:
   Destination Pattern=42104060, Called Number=42104060, Digit Strip=FALSE
   Called Number=42104060(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=42445AFA-7E69-11DF-80A9-FCFBFBA11610, Outgoing Dial-peer=42104060
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=42104060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48807B30, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9043383245,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=42104060(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=42104060, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 23 20:47:19 dst:  cc_get_feature_vsa count is 2
Jun 23 20:47:19 dst: :FEATURE_VSA attributes are: feature_name:0,feature_time:1253757736,feature_id:770
Jun 23 20:47:19 dst: //750/42445AFA80A9/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jun 23 20:47:19 dst: //750/42445AFA80A9/CCAPI/ccCallSetContext:
   Context=0x4A5A8B7C
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/ccSaveDialpeerTag:
Jun 23 20:47:19 dst: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x80DF
Jun 23 20:47:19 dst: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x00DF
        Facility i = 0x9F8B0100A117020101020100800F4141524F4E5320414E47454C412020
                0xA117020101020100800F4141524F4E5320414E47454C412020
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = AARONS ANGELA
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/cc_api_call_facility:
   Interface=0x491ABDB0, Call Id=749
Jun 23 20:47:19 dst: //750/42445AFA80A9/CCAPI/ccCallFacility:
   Call Id=750
Jun 23 20:47:19 dst: //749/42445AFA80A9/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Jun 23 20:47:29 dst: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x00DF
        Cause i = 0x82E6 - Recovery on timer expiry
Jun 23 20:47:29 dst: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80DF
Jun 23 20:47:29 dst: //749/42445AFA80A9/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x491ABDB0, Call Id=749
   Call Entry(Responsed=FALSE, Cause Value=102, Retry Count=0)
Jun 23 20:47:29 dst: //750/42445AFA80A9/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=102, Call Entry(Responsed=FALSE, Cause Value=102)
Jun 23 20:47:29 dst: //750/42445AFA80A9/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jun 23 20:47:29 dst: //749/42445AFA80A9/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Jun 23 20:47:29 dst: //749/42445AFA80A9/CCAPI/cc_api_get_transfer_info:
Jun 23 20:47:29 dst: //750/42445AFA80A9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48807B30, Tag=0x0, Call Id=750,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jun 23 20:47:29 dst: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 23 20:47:29 dst: :cc_free_feature_vsa freeing 4ABAD320
Jun 23 20:47:29 dst:  vsacount in free is 1
Jun 23 20:47:29 dst: //749/42445AFA80A9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x491ABDB0, Tag=0x0, Call Id=749,
Jun 23 20:47:29 dst: :cc_free_feature_vsa freeing 4ABAD400
Jun 23 20:47:29 dst:  vsacount in free is 0
Router#show isdn timers
    ISDN Serial0/0/0:23 Timers (dsl 0) Switchtype = primary-ni
        ISDN Layer 2 values
         K     =   7 outstanding I-frames
         N200  =   3 max number of retransmits
         T200  =   1.000 seconds
         T202  =   2.000 seconds
         T203  =  30.000 seconds
        ISDN Layer 3 values
         T301  = 300.000 seconds
         T303  =   4.000 seconds
         T304  =  20.000 seconds
         T305  =  30.000 seconds
         T306  =  60.000 seconds
         T307  = 180.000 seconds
         T308  =   4.000 seconds
         T309    Disabled
         T310  = 400.000 seconds
         T313  =   4.000 seconds
         T316  =  30.000 seconds
         T318  =   4.000 seconds
         T319  =   4.000 seconds
         T322  =   4.000 seconds
         T323  = 120.000 seconds
         T3OOS =   5.000 seconds
         TGUARD=   8.000 seconds, Expiry = REJECT_CALL
    ISDN Serial0/2/0:23 Timers (dsl 1) Switchtype = primary-ni
        ISDN Layer 2 values
        ISDN Layer 3 values
         T309    Disabled
         T310  =  30.000 seconds
Router#
Aaron Harrison Thu, 06/24/2010 - 00:02
Hi Jason
It's common to reduce the H225 TCP timeout so that it fails over quicker to the backup peers:
voice class h323 1
h225 timeout tcp establish 3
then on each VOIP dial-peer
voice-class h323 1
Aaron
Please rate helpful posts....
