clear config - interface
Answered Question
hi! what's the command to clear an gigaethernet internface config on a 4506e sw? currently there are lots of qos and security stuffs on some of the gigaethernet port. instead of using the no command for each of the line, is there a command to clear all these config? i just want to configure access vlan on the port.
thx.
Correct Answer by Lim Seow Hua about 7 years 2 days ago
You can try to use below command on the configuration mode....
xxx-xxx(config)#default interface gigabitEthernetx/x - specify the port that you would like to clear the configuration...see whether it works or not.
And let me know later
Overall Rating: 5 (3 ratings)
Correct Answer
Lim Seow Hua Wed, 06/23/2010 - 20:52
Asbathc786 Tue, 01/05/2016 - 03:27
Hi there,
I tried the above command and it works.
