B-ACD with CME-as-SRST in CME 8 IOS 15.1
Jun 23rd, 2010
  • Bronze, 100 points or more
Running UCCX with a Remote Site that has local PRI. Duirng a WAN outage I want to provide some sort of basic queing.  So I am wondering if B-ACD is supported with CME-as-SRST? I only see references to SRST not CME-as-SRST, or should I just do some simple ephone-hunt out of .aef in CUE 8.0.1?
Using IOS 15.0(1)XA3 which has telephony-service version 8.0, cme-bacd-3.0.0.2.tar, and also have a NME-CUE running 8.0.1 in same router.
Anyone have some hands on experience and vouches this works for the newer 8x software versions listed? Most B-ACD info I find is from CME 3x/4x days.
Configuring B-ACD
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html#wp1003335
Aaron Harrison Thu, 06/24/2010 - 00:37
  • Community Spotlight Award,
    Member's Choice, May 2015
Yeah, you can use it - if it works for CME, and works for SRST, then it will work for CME-as-SRST (which is effectively CME with some auto provisioning features..).
Latest ver appears to be 3.0.0.2 for 'CME 7.1 and later' : http://www.cisco.com/pcgi-bin/swsrch/SWSearch_results.cgi/SWSearch_results.cgi/SWSearch.txt?isChild=false&file_delimiter=contains&searchPhrase=cme-bacd
Aaron
Please rate helpful posts...
