Intermittent DN Internal Mask
Answered Question
Jun 24th, 2010
CM 4.2.3 SR4b
I'm using the external phone number mask setting on the DN configuration of a particular phone, and I've ensured that on my route patterns Use Calling Party's External Phone Number Mask is enabled.
I have an IP phone range with extension range 2000-4000 route pattern [2-4]xxx which has use external phone number mask enabled yet when dialing these numbers it still displays my actual DN number.
However if I add a more detailed route pattern 450X and use the same options then it correctly displayed the masked number if I say dial extension 4501
I can't see a clash in my route patterns so I'm wondering why it doesn't work with the more generic [2-4]xxx route pattern.
Nick
Correct Answer by Jaime Valencia about 6 years 8 months ago
OK, not sure if I'm getting this right.
Internal DNs: 2000-4000
"However if I add a more detailed route pattern 450X and use the same  options then it correctly displayed the masked number if I say dial  extension 4501"
Are you calling the PSTN? Thru an ICT?
If you're calling from one IP Phone to another within your same cluster you don't need route pattterns, you need to do this in a translation pattern
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/24/2010 - 07:57
java
nickpalmermorewood Wed, 07/14/2010 - 03:56
Thanks for the pointers Java. I arranged out route patterns and then started using translation patterns as advised.
Thanks, Nick
