Grant bandwidth (CBWFQ?)
Jun 24th, 2010
Hi Team,
i am new to the community so i greet you all!
My doubts and problems are related to the need to shape the traffic of a class granting a minimum bandwidth.
We have a 7206-VXR so we have Gigabit physical interfaces, our SP is granting 200Mbps.
The shape is working fine but the bandwidth command don't trigger couse, for my router, there's no congestion.
I think that this is a common problema and maybe i am trying to solve in the wrong way.
Any suggestion is appreciated
Thanks in advance
Denis
amahendi Sat, 07/17/2010 - 09:21
  • Cisco Employee,
Hi Denis,
Shaping using the 'shape' cli defines the max rate for a class; whereas, the 'bandwidth' cli defines the minimum bandwidth guarantee for that class under functional congestion.
For example,
policy-map test
class A
  shape average percent 20
class B
   bandwidth percent 10
  class C
    bandwidth percent 30
- Traffic through class A will *always* get shaped to 20% of intf bandwidth. Doesn't matter whether the interface is congested or not.
- Traffic through class B and Class C will get a *minimum* guarantee of 10 and 30% of intf bandwidth when the interface is congested. When the interface is not congested, then there is really no need for a queueing policy (~ bandwidth cli) and the queueing part of the policy won't kick in. So, class B / class C can basically use the entire intf bandwidth if there is no traffic through the other (bandwidth) classes. However, should the physical interface be congested (tx_ring is full) then queueing kicks in and each class is given a minimum guarantee that's configured. The remaining bandwidth is shared amongst the bandwidth classes in the ratio of guarantees.
- Abhi
Related Content
