06-24-2010 05:15 AM - edited 03-04-2019 08:52 AM
Hello everyone.
I have a DSL Implementation with PPP Dialer on my 1841. I have a problem with ISP, in some cases the PVC circuit goes down, then atm interfaces, flaps, after line issue, all interfaces goes UP again less Virtual Access. This is my ATM and Dialer 1 Config:
interface ATM0/0/0
no ip address
no ip mroute-cache
logging event atm pvc state
logging event subif-link-status
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
interface ATM0/0/0.1 point-to-point
no ip mroute-cache
snmp trap link-status
pvc 8/32
oam-pvc 0
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip access-group 111 in
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XXX
ppp chap password XXX
crypto map clientmap
As you can see, IP Addreess is negotiated and after failures, Virtual Access does not get IP from ISP and remains Down.
ATM0/0/0 unassigned YES NVRAM up up
ATM0/0/0.1 unassigned YES unset up up
NVI0 10.X.X.X YES unset up up
Virtual-Access1 unassigned YES unset down down
Dialer1 unassigned YES IPCP up up
The only way to restablish the connection is reloading the router.
My questions are:
1.- How can I avoid virtual-access interface gets without IP?
2.- How can a reset/restablish PPP session without reload the router?
Thanks a lot.
06-24-2010 06:14 AM
Hi Carlos,
Add below commands to Dialer1 interface & check.
no ip redirects
no ip unreachables
no ip proxy-arp
I hope it'll work after that.
Dasuntha
06-24-2010 06:45 AM
Hello, thanks for quick answer. Can you tell something about the behaivor of these commands in my config?
Thanks!!
