Need Help Configuring EtherChannel
Jun 24th, 2010
Having a really hard time here and hopefully someone on this forum can help me get this EtherChannel working. I have two Cisco 3560G 24 port switches. I am using ports 25-28, with SFP modules, between the switches as an EtherChannel. The problem is, all 8 ports have no link lights. All ports in the EtherChannel are down. This is the config that I have already entered:
Config t
Interface range gi0/25-28
switchport mode trunk
switchport allowed vlan 1,2
channel-group 1 mode on
End
interface Port-channel1
switchport trunk allowed vlan 1,2
When I issue a sh ip int br command, indeed the ports in question are down including the port-channel1. When I issue the show spann blocked ports command, it says Number of blocked ports (segments) in the system: 0
What to do?
Further information: Sorry for the length!!
ISCSI2#show etherchannel detail
                Channel-group listing:
Group: 1
Group state = L2
Ports: 4   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Gi0/25
Port state    = Down Not-in-Bndl
Channel group = 1           Mode = On              Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 0d:16h:39m:03s
Port: Gi0/26
Port: Gi0/27
Port: Gi0/28
                Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 0d:16h:39m:03s
Logical slot/port   = 2/1          Number of ports = 0
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Not-Inuse
Protocol            =    -
Port security       = Disabled
ISCSI2#
Finally, these are the configs for the interfaces in question:
ISCSI2#show run int port-channel1
Building configuration...
Current configuration : 127 bytes
end
ISCSI2#show run int gi0/25
Current configuration : 158 bytes
interface GigabitEthernet0/25
switchport trunnk allowed vlan 1,2
channel-group mode on
end
ISCSI2#
joshiaroon Thu, 06/24/2010 - 06:39
On int g0/25 you are missing channel-group number .
vegas5882010 Thu, 06/24/2010 - 06:55
That was a typo. It is actually correct on both switches. Each port in the EtherChannel has the same config.
burleyman Thu, 06/24/2010 - 06:59
  • Blue, 1500 points or more
Could you post the the config for both switches and the output of this command on both switches
show etherchannel 1 sum
Mike
vegas5882010 Thu, 06/24/2010 - 07:03
I may just have found the issue. It seems that the configs are not the same! on switch 1 I have put in a switchport access vlan 2 command but not on switch 2. Now the question is, before I remove it, should that command be in there or no? Vlan 2 is our ISCSI vlan which is what these switches are being used for. Do we need to specify switchport access vlan 2?
Thanks guys.
burleyman Thu, 06/24/2010 - 07:20
Looks like you have these configured as a trunk and you are allowing vlan 1 and 2 on the trunk so you should not need that.
Mike
vegas5882010 Thu, 06/24/2010 - 07:34
Well, I got it to work by removing the "switchport access vlan 2" command from switch 1. I then issued a shut and no shut on port-channel1. The interfaces came up. Now, what can I do to verify that this config is working? I basically need to prove that vlan 2 is available on both sides. I can certainly ping, but what other commands can I issue?
burleyman Thu, 06/24/2010 - 07:37
Run the command
on both switches.
Mike
vegas5882010 Thu, 06/24/2010 - 07:43
Each switch shows the ports as bring in a "P" state. The Port-channel looks like this: Po1 (SU)
burleyman Thu, 06/24/2010 - 08:31
Then the etherchannel is up. Are the switches in vlan 1 or 2?
Mike
vegas5882010 Thu, 06/24/2010 - 10:14
I figured it out. I had my laptop plugged into the wrong port. It's on vlan 1, not vlan 2. Therefore it is unable to ping across vlans.
Thanks for all your help. Learned alot today!
On a final note, what commands or tools can I use that will "show" that we do indeed have a 4GB trunk across these switches? Any bandwidth commands or tools around?
