unity express issue , hope some one can help me.
Jun 24th, 2010
I have a unity express (NM-CUE)  version 2.2  , I want to upgrade this card to 7.0.1 ,
but when I  choice  ***  to upgrade and  write some infomation as below
ServicesEngine boot-loader> config
IP Address [10.201.74.60] >
Subnet mask [255.255.255.192] >
TFTP server [10.201.74.30] >
Gateway [10.201.74.1] >
Default Helper-file [cue-vm-k9.nmx.7.1.1.pkg] >cue-installer.nm-aim.7.0.1
Ethernet interface [internal] >
Default Boot [disk] >
Default bootloader [primary|secondary] [primary] >
above all can complete, but when I still doing this upgrade process not complete,, info as below
Please select from the following
1       Install software
2       Reload module
3       Disk cleanup
(Type '?' at any time for help)
Choice: 1
Package name: cue-installer.nm-aim.7.0.1
Server url: ftp://10.201.74.30/
Username:
Password:
Downloading ftp cue-installer.nm-aim.7.0.1
Bytes downloaded :  6373376
pycurl.error: invalid return value for write callback -1 2048
Error: Operation Aborted
who can tell me how can resolve this issue ..  or  tell me another salvation method  , many thanks ..
Rob Huffman Thu, 06/24/2010 - 07:36
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kun,
I don't believe the upgrade from CUE 2.2 is supported. You would need to be
at 2.3 as a minimum release version as a first step
Upgading Cisco Unity Express by Performing Software Upgrade
Use this procedure to upgrade to version 7.0:
–From version 2.3.1 and its maintenance versions 2.3.2, 2.3.3, 2.3.4
–From version 3.0.1 and its maintenance versions 3.0.2, 3.0.3, 3.0.4
–From versions 3.1.1 and 3.1.2
–From version 3.2
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upgrade.html
Table 32
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/rel_notes/rel_notes.html#wp245809
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
