Login problem in that the radius server is not configured. And the local user does not authenticate
Jun 24th, 2010
When trying to login, the message appears "No radius server configured" and the local user does not authenticate. How do I access without rebooting the Switch 6500 with CatOS.
Panos Kampanakis Thu, 06/24/2010 - 09:15
  • Cisco Employee,
Unfortunately if you are locked out you need to do password recovery and you will need a reboot for that.
I hope it helps.
PK
maccacio Thu, 06/24/2010 - 09:48
Hi PK.
Thanks for your Attention. You know how to insert a line configuration via SNMP RW  "set radius server 10.112.15.21 auth-port 1645 primary"?
I believe this way or can I work around the problem.
