wan question
dkblee
hi! i'm subscibing for wan connection for connection between branch sites. there are 2 types of connection recommended, optical and adsl. Optical to connect to the internet and adsl for vpn tunnelling between sites. What's the different between optical and adsl in this case? what's the different in port types or devices required for these 2 setups?
for the optical connection, which i;m not too sure what kind of connection is that? can i do a vpn tunnelling (backup) to the adsl' vpn site-to site tunnelling + as an alternative path for the user to go to the internet?
thx
Giuseppe Larosa
Hello Dbklee,
it is not possible to answer to your question as optical simply means they give you a fiber connection it can be a 10 Mbps bidirectional, more or less.
ADSL is asymmetric in nature with different speeds for download and upload directions but it is cheaper.
So I would say the difference can be this one.
if you want  to have the user go to the internet using ADSL as secondary path this is possible it is just enough to NAT when destination address is not a private address of the other site.
Sending traffic over a vpn tunnel to site2 and then to go out to the internet from site2: this may be possible but it is not reasonable at least in standard scenarios.
Just to say you can exit to the internet and you can have a VPN connection exiting from the same link at the same time.
Hope to help
Giuseppe
