Bulk UDP Update
Answered Question
Jun 24th, 2010
We have over 3000 User Device Profiles that need the User Hold MOH Audio Source field changed back to <none>  on CUCM 7.13
Can't seem to find an easy to do a bulk update for UDPs - is this not possible or am i missing something obvious?
Correct Answer by Aaron Harrison about 6 years 11 months ago
Yeah, that would have been tricky :-)
Here's a slight edit; the last param can now be left blank whereas before it would generate an error.
So to set none:
updateDeviceProfile,name,russell,userLocale,
Aaron
Correct Answer by Aaron Harrison about 7 years 4 days ago
It is a terrible thing.
The only way I've found to address this is via the AXL API, or by being evil and directly updating the DB.
A while back I posted a rudimentary tool that can do this sort of thing for you  - see my post : https://supportforums.cisco.com/message/3036771#3036771
Essentially the input CSV file you would need would have two entries for each UDP:
updateDeviceProfile,name,UDPDAVE1234,networkHoldMOHAudioSourceId,2
updateDeviceProfile,name,UDPDAVE1234,userHoldMOHAudioSourceId,2
updateDeviceProfile,name,UDPSALLY1235,networkHoldMOHAudioSourceId,2
updateDeviceProfile,name,UDPSALLY1235,userHoldMOHAudioSourceId,2
etc
A lot of lines, but you should be able to whip this up in Excel easy enough - by exporting all UDP names from CCM if you like, or a subset, or whatever. You may find it easier to create two files with one line for each UDP, and then search/replace networkHold for userHold, and run the two files seperately.
Oh - and always do a single-line input file first to verify your spelling/results.
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
afmmanicke Thu, 06/24/2010 - 11:54
Under Bulk Administration there's User Device Profiles -> Addu/Update Lines -> Update Lines...
rchaseling Thu, 06/24/2010 - 12:58
Yeah i understand that but i don't need to update the line.......i need to update the Device Profile itself.
Correct Answer
Aaron Harrison Thu, 06/24/2010 - 23:50
  • Community Spotlight Award,
    Member's Choice, May 2015
etc
Aaron
rchaseling Fri, 06/25/2010 - 02:15
Aaron,
That does the trick perfectly!!!!!! Your help is priceless.......by putting the userHoldMOHAudioSourceId,0 field in i can get everyone back to in their profile & now just change the default MoH in service parameters. Job done!!
Cheers
rchaseling Fri, 06/25/2010 - 02:23
Aaron,
Actually one last question about extracting all the UDP names - is there a command i can run from CLI to do this? Or can i extract them from the GUI?
Cheers
Aaron Harrison Fri, 06/25/2010 - 03:45
Happy my dubious coding skills have helped you out :-)
You can go into the Bulk Admin, there's an export/import function. This can export most things into a .tar file, unzip that and it contains a CSV.
You can select then from the DB as an alternative, if your UDPs are named something obvious you could use:
Run sql select name from device where name like 'UDP%'
Run sql select name from device where name like '%UDP%'
(the % is a wildcard)
Or try this, and see if the results look sensible (254 should enumerate to 'Device Profile' according to google)
Run sql select name from device where tkclass = 254
(if it complains about syntax try putting '254' in single quotes - sorry, not near a CCM at the moment).
Aaron
rchaseling Fri, 06/25/2010 - 05:43
Bulk Admin - i should have known that....thanks again
rchaseling Thu, 07/15/2010 - 05:55
Hi Aaron,
Trying to do the same thing but with the User Locale in the UDP. I need to change them all back to or to English United States from English United Kingdom. Can't seem to get it to work though
Russell
rchaseling Thu, 07/15/2010 - 07:52
I am trying "updatePhone,name,russell,UserLocale,0
- it says it competes successfully but the Locale doesn't change
Aaron Harrison Thu, 07/15/2010 - 08:46
Appropriate input would be :
updateDeviceProfile,name,russell,userLocale,English United States
It's a different call (updateDeviceProfile) for UDPs, name should refer to the UDP name (i.e. the UDP is called russell in this case) and the 'userLocale' field to update is case sensitive.
AXL likes to positively acknowledge lots of stuff that doesn't actually work; it's very helpful like that.
Aaron
rchaseling Thu, 07/15/2010 - 09:17
Thanks Aaron. Do you know how to get it back to - as this is really what i am after.......
Many many many thanks again
Russell
Correct Answer
Aaron Harrison Thu, 07/15/2010 - 10:01
So to set none:
Aaron
rchaseling Fri, 07/16/2010 - 01:21
Aaron,
Thank you once again.......you are a life saver!!!!! I'd give you 20+ if i could
Russell
Aaron Harrison Fri, 07/16/2010 - 03:50
Glad it worked for you :-)
Aaron
cscnesindia Thu, 09/15/2011 - 08:25
Hi Aaron,
This works perfectly fine to change the description field for device profiles, But How do we update Line 1 ASCII Display (Internal Caller ID) using via AXL API, we are using CUCM 7.1.3
Thanks in advance.
