Richard Ortiz Thu, 06/24/2010 - 10:23
Currently my remote end site is having an issue (hard drive failure on the logger) with their Central Controller at their Cleveland datacenter. They have stopped the processes on the logger, router and HDS. They also have a group that specifically makes changes to their ICM scripts using script editor. If they are running in ICM Simplex on the central controller, can they continue to make changes to their call routing scripts in ICM? Will the script changes replicate over to the Cleveland central controller once they turn it back up?
What is the plan to bring this machine back? Will you be restoring the Logger side B database from a SQL back up? Or will you be installing a blank database, using sync loggers to push the config data from the A side, then allowing the rcv process to synchronize historical data?
You normally can make the changes and they will replicate. If I were you, I would check with TAC.
Geoff
Related Content
