1000base-t vs 1000base-tx
Answered Question
Jun 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
One end of the link supports 1000BASE-T and the other end supports 1000BASE-TX. I realized that with BASE-T you must use CAT 5 and BASE-TX  you must use CAT6. Will this work if I use CAT6 cable to link them together?
Correct Answer by Ganesh Hariharan about 7 years 1 month ago
The maximum allowed length of a Cat-6 cable is 100 meters (330 ft) when used for 10/100/1000baseT
1000BASE-T will run on Category 5 and Category 5e cabling at distances to 100 meters and the maximum allowed length of a Cat-6 cable is 100 meters (330 ft) when used for 10/100/1000baseT.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by konigl about 7 years 1 month ago
Yes, it will work with CAT6.  For 1000BASE-T you need CAT5 or better (CAT5e, CAT6, CAT7).
Overall Rating: 5 (2 ratings)
Correct Answer
konigl Thu, 06/24/2010 - 16:04
  • Gold, 750 points or more
Correct Answer
Ganesh Hariharan Thu, 06/24/2010 - 23:06
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to Help !!
Ganesh.H
