PIMG Upgrade OK?
Jun 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Running Unity Connection version 7.1.2ES9.21900-9 with x6 analog PIMGs (DMG1008LS) running software version 6.0.1.21.  About once a week a port goes bad on a PIMG.  Can not always restart a PIMG to fix, although does not alway remedy, so I have AT&T busy the bad port.  I see there is a new version of software up on the Cisco website, version 6.0.SU3.2.  Is it ok to load on Unity Connection V 7.1?
Rob Huffman Thu, 06/24/2010 - 12:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Beth,
Yes, I would feel safe using this new version (as Tray notes in the
attached thread the versions don't post until they have been tested
with the Cisco UC products).
I would also look at the Bug that Tommer nicely notes that references the Port
Lock-ups. And the need to upgrade to Unity Connection 7.1(3x)
https://supportforums.cisco.com/message/3010391#3010391
Cheers!
Rob
Beth Verish Thu, 06/24/2010 - 12:53
Ron,
Thanks so much for the prompt response. We have been suffering with PIMGs for a year now. We are moving users to VoIP but will probably have to keep one PIMG in the end. I hope to do the upgrade this weekend.
Beth
Beth Verish Thu, 06/24/2010 - 16:02
Hi Ron,
Not trying to be too paranoid but I noticed there is an extra file in this version, ls_6.0.SU3.2.002.pkg.  Is this new with 6.0SU3.2?
Thanks again!
Beth
Rob Huffman Fri, 06/25/2010 - 06:24
  • Hall of Fame,
    Founding Member
Hey Beth,
No worries
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
The *.pkg file is a package file that is a bundle of all of the runtime files associated with the new release for the specific model. This file allows the user to upgrade all of the runtime models (e.g. *.app, *,dsp, *.fsh, etc.) with the download of a single file. Note: This file can only be used when upgrading from a unit that is running Version 6.0 or greater.
Cheers!
Rob
