VG224 No Dial Tone
Jun 24th, 2010
I have configured a new VG224 just as an existing one is configured and am running across an issue with the ports not providing dial-tone when they are registered to CUCM 7.1. They are configured as SCCP. Hear talk-battery but do not receive dial tone. The ports that aren't registered atleast provide a busy signal. Any help would be greatly appriciated.
Brad Martin Tue, 07/24/2012 - 13:24
  • Bronze, 100 points or more
I'm experiencing the same problem. One port has talk-battery but no dial tone. All other ports seem to be working. IOS version 12.4.22T3. Callmanager version 8.6.2. All ports are mgcp configured as POTS. Any troubleshooting hints would be appreciated.
Bernece Johnson Tue, 07/24/2012 - 13:39
Can you post the config of your VG224? It took me a while to get it to work without ad DN on the line. If you post the config I will be able to determine what I did to resolve the issue.
Brad Martin Tue, 07/24/2012 - 13:50
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname publco-scwc1-vg02
boot-start-marker
boot system slot0:/vg224-i6k9s-mz.124-22.T3.bin
boot-end-marker
logging message-counter syslog
logging buffered 4096
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa session-id common
clock timezone MST -7
clock summer-time MDT recurring
no ip source-route
ip cef
no ipv6 cef
stcapp feature access-code
voice service voip
modem passthrough nse codec g711ulaw
voice-card 0
dsp services dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.0.11 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.1
no ip http server
no ip http secure-server
ip access-list standard SNMP-READ
permit 10.0.6.0 0.0.1.255
permit 10.1.6.0 0.0.1.255
ip access-list extended TELNET
permit ip 10.0.6.0 0.0.1.255 any
permit ip 10.1.6.0 0.0.1.255 any
permit ip 192.168.1.0 0.0.0.255 any
logging 10.0.7.10
logging 10.1.7.10
logging 10.1.7.14
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps aaa_server
snmp-server enable traps config
snmp-server enable traps envmon
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.0.0.15 10.0.0.14
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.0.10 10.0.0.14
ccm-manager config
mgcp
mgcp call-agent 10.1.0.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
no mgcp fax-relay sg3-to-g3
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp behavior g729-variants static-pt
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 10.1.0.10 identifier 1 priority 1 version 7.0
sccp ccm 10.0.0.14 identifier 2 priority 2 version 7.0
sccp
dial-peer voice 99920 pots
service mgcpapp
port 2/0
dial-peer voice 99922 pots
service mgcpapp
port 2/2
dial-peer voice 99923 pots
service mgcpapp
port 2/3
dial-peer voice 99924 pots
service mgcpapp
port 2/4
dial-peer voice 99925 pots
service mgcpapp
port 2/5
dial-peer voice 99926 pots
service mgcpapp
port 2/6
dial-peer voice 99927 pots
service mgcpapp
port 2/7
dial-peer voice 99928 pots
service mgcpapp
port 2/8
dial-peer voice 99929 pots
service mgcpapp
port 2/9
dial-peer voice 999210 pots
service mgcpapp
port 2/10
dial-peer voice 999212 pots
service mgcpapp
port 2/12
dial-peer voice 99921 pots
service mgcpapp
port 2/1
dial-peer voice 999214 pots
service mgcpapp
port 2/14
dial-peer voice 999211 pots
service mgcpapp
port 2/11
dial-peer voice 999215 pots
service mgcpapp
port 2/15
dial-peer voice 999216 pots
service mgcpapp
port 2/16
dial-peer voice 999217 pots
service mgcpapp
port 2/17
dial-peer voice 999218 pots
service mgcpapp
port 2/18
dial-peer voice 999220 pots
service mgcpapp
port 2/20
dial-peer voice 999221 pots
service mgcpapp
port 2/21
dial-peer voice 999222 pots
service mgcpapp
port 2/22
dial-peer voice 999223 pots
service mgcpapp
port 2/23
dial-peer voice 999219 pots
service mgcpapp
port 2/19
dial-peer voice 999213 pots
service mgcpapp
port 2/13
line con 0
line aux 0
modem Host
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
access-class TELNET in
exec-timeout 30 0
scheduler allocate 20000 1000
ntp server 10.0.4.1
ntp server 10.1.4.1
end
Bernece Johnson Wed, 07/25/2012 - 07:56
My memory is kind of foggy on the reasons why, but I did find that the timeouts ringing infinity is on all of my voice-ports.
voice-port 2/2
timeouts ringing infinity voice-port 2/2
Since all of your ports are registered with call manager this is the only thing I see that may help. If you add this to a port and still are not receiving dial-tone, let me know and I can dive into it further.
