QoS IP Precedence command
Jun 24th, 2010
Does anyone know if the ip precendence command is available in Cisco IOS Software, C2600 Software (C2600-TELCO-M), Version 12.4(19b), RELEASE SOFTWARE (fc1).  c2600-telco-mz.124-19b.bin"
Thank you
Giuseppe Larosa Thu, 06/24/2010 - 12:47
Hello Ikadlik,
you should be able to use match ip precedence or match precedence or set ip precedence or set precedence inside route-maps or policy-maps
the command without the ip can apply to IPv6 packets also, the command with the ip keyword should apply only to IPv4 packets
see
match ip precedence
The match ip precedence command is replaced  by the match  precedence command. See the match precedence command for more  information.
see
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1034932
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1035353
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_s1.html#wp1059755
it looks like some modern IOS support  only the version without the ip keyword
Hope to help
Giuseppe
