RV042 and iphone VPN
Jun 24th, 2010
I seem not to be abled to connect my iphone to RV042 VPN router. VPN is working cuz im abled to connect through QuickVPN client on external computer. Sadly i dont know how to use the client certificate (exported from the RV042) on my iphone (it does not support the .pem format). When setting up a Client to Gateway tunnel with a preshared key and setting up the Cisco VPN client in the iphone accordingly things goes wrong. Connection is accepted but stalls with log message:
(NATT) Initial Main Mode message received on xx.xxx.xx.xx:500 but no connection has been authorized. Check your tunnel endpoint (gateway) setting.
If somebody has an iphone IPsec VPN working on this kind of router please let me know. I really wanna ask you some questions on how to set this up.
Rick
itelcomsa Thu, 05/02/2013 - 15:53
I have the same problem.
RV042 (latest firmware) with fixed Public IP
Active PPTP server, username and password.
windows PC I can connect,
From Iphone 4 I can not not work,
Someone found a solution?
thanks
