Skype for SIP with CUCM 7.1.3
Answered Question
Hi all,
I've never work with SIP before and I am trying to understand how to get Skype for SIP to talk to CUCM 7.1.3. I've got a profile set up for Skype for SIP in Skype Manager and I am kinda stuck here.
Has anyone successfully got this up and working ? Please share your experience, walk me through the configuration on both ends (Skype and CUCM).
How does a Skype user call an IP phone extension  and vice versa ?
Where in CUCM do you configure to handle incoming calls from Skype ?
Thanks in advance !!
D.
Correct Answer by David Hailey about 6 years 8 months ago
I haven't used Skype for SIP so I apologize that I don't have much advice on how to get this working.  However, I did run across a few threads a month or so ago that mentioned it and it peaked my interest and I came across this thread on the Skype forums.  I'm not sure if the status has changed but I thought I'd share it with you just so you are aware.  As of June 1, 2010 a Skype Staff Member replied to a question regarding support for CUCM and noted that you need to use CUBE at this time as CUCM does not currently support the necessary authentication type.  Again, just a reference of something that you may want to be aware of before you dive too deep:
http://forum.skype.com/index.php?showtopic=620893&view=&hl=cisco&fromsearch=1
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Thu, 06/24/2010 - 14:33
Hailey
Hello David,
As always David I appreciate your response !!! It seems like it's possible. I am trying to reach out to see if anyone actually got it working.
And by the way, thanks for your help with my Unity upgrade. I did the upgrade on last Saturday, went from 4.0.3 to 4.0.5 and all went well. I am about ready to jump to Unity Connection 8.x, hopefully in the next couple weeks.
Thanks again David !!
D.
David Hailey Thu, 06/24/2010 - 15:10
Glad it all worked out.  Let me know if you have any questions about the path to Unity Connection and/or configuration, etc.
Hailey
Marwan ALshawi Wed, 07/28/2010 - 23:21
i have question here
in the outbound dial peer bellow
dial-peer voice 2 voip
description Skype Outgoing
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
this will use the sip config
sip-ua
credentials username password realm sip.skype.com
authentication username password
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
this will sip dns of sip.skype.com
how the router will get the IP address of the URI
do we need to configure a DNS i the router such as compnay internal or internet external DNS ?
also if the calls go through a FW will NATing make any issues ?
thank you
david-lima Thu, 07/29/2010 - 06:38
Hi all, does any one make it work???. If yes, please share the  config steps.
In the skype page I see that Cisco PBX is supported, but I can't find any configuration guide.
Thanks a lot
David
