G722 supported for Call Monitoring/Recording Built in Bridge
Answered Question
Jun 24th, 2010
We are using a 3rd party SPANless recording/monitoring solution that uses the 7941/61, 7942/62 built in bridge function. Are there any codec restrictions for Built in bridge? For example, is G722 supported? Currently, the phone firmware is SCCP4x.9-0-2SR1S. Thanks.
Correct Answer by Jaime Valencia about 6 years 9 months ago
Without knowing your version I'll think you're running 8.0(2).
This feature supports any codec, the limitation might come from the recording system if there is a problem.
Review this
Codec for Monitoring and Recording Calls
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsmr.html#wp1060558
In case your recording systems doesn't work with G722 you can disable it for devices you need to record the calls using the CUCM service parameter:
G.722 Codec Enabled: Required Field This parameter determines whether Cisco Unified Communications  Manager allows G.722 negotiation for all, some, or no devices. Valid  values specify Enabled for All Devices, Enabled for All Devices Except  Recording-Enabled Devices, or Disabled.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 06/24/2010 - 16:09
  • Cisco Employee,
  • Hall of Fame,
    2011
Review this
java
kbyrd Thu, 06/24/2010 - 16:36
The vendor states they can support G711, G729, or G722. We are running v7.1.5.10000-12.
The service parameter you referenced does not appear to be available in 7.1.5. Due to transcoding issues for calls set up as G722, the parameter "Enabled for All Devices Except  Recording-Enabled Devices" would be useful.
