PIX 525 showing inconsistent ARP entries during a client vpn connection
Jun 24th, 2010
My PIX 525 is showing inconsistent ARP entries during a client vpn connection. Attached is a screenshot of the arp table on my pix.
I was able to successfully ping 10.0.3.70, 10.0.3.10, 10.0.3.30 from my remote end connected using the vpn client but the arp entries on the PIX showed up on different zones but not on the right zone which is supposed to be zone3.
Please advise.
Marcin Latosiewicz Fri, 06/25/2010 - 01:51
Brian,
What's the PIX version?
Are the mac address entries correct?
Are there any L3 devices around PIX that might be doing proxy ARP or similar?
Marcin
