IOS 15 and voice service voip changes
Jun 24th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Why is h225 timeout tcp establish gone from voice service voip/h323 and only left in voice class h323 ? Like I really want to put it on each dial peer?!?!? Why remove it from global?  What is h225 timeout setup ?
Actual working config;
voice service voip
h323
  h225 timeout setup 2
  h225 display-ie ccm-compatible
voice class h323 1
  h225 timeout tcp establish 3
David Hailey Thu, 06/24/2010 - 22:01
Jason,
I can't speak on the reasoning for the changes you've come across in IOS 15.  But, I think I can at least address your last question about the h225 timeout setup.  This was addressed (slightly different info) in an Ask The Expert thread.  See:  https://supportforums.cisco.com/message/495940#495940.
So, in your example:
voice service voip
  h323
The default h225 timer would be reduced to 2 seconds before hunting to the next dial peer.
Hailey
