1250AP cannot join 5508 WLC
Jun 24th, 2010
I am look for config an 1250AP (AIR-LAP1252AG-C-K9) to Join in a 5508 wireless cotroller. When the AP first time join in, I can see the AP in the WLC. But a couple of sec, the AP will lose in the WLC. I checked console in the AP. I cannot type anything in the AP console.
The join log in the WLC is "mage data request received from an unsupported AP"
What's wrong of the AP or Wireless controller ?
This is the DHCP setting in default gateway
ip dhcp pool dhcp107
   network 148.164.107.0 255.255.255.0
   default-router 148.164.107.254
   option 43 hex f104.94a4.6dbc
   option 60 ascii "Cisco AP c1250"
   dns-server 148.164.52.153
   lease 364
This is the WLC setting
System Inventory
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: AIR-CT5508-K9,  VID: V01,  SN: FCW1412L0G6
Burned-in MAC Address............................ 88:43:E1:63:12:00
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 25
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.98.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... N/A
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... asch-han5538-wlc
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 148.164.107.220
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 35 mins 27 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... CN  - China
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Network Information
RF-Network Name............................. SSCI
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
IP/MAC Addr Binding Check .................. Enabled
Leo Laohoo Thu, 06/24/2010 - 21:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Is the console working?
albert.ho Thu, 06/24/2010 - 22:53
When the AP is not connect the network. And I hard reset it (go back to autonomous AP).
The console is workable. It can be type command.
But when AP plug in the network. It will be auto run a flash "flash:/c1250-rcvk9w8-mx".
After the image complete to load, it cannot type anything.
Leo Laohoo Thu, 06/24/2010 - 23:00
  • Hall of Fame,
    2017 LAN, Wireless
What you are saying is that your AP won't join the controller after booting the "rcv" IOS file.  Is this correct?
Leo Laohoo Sat, 06/26/2010 - 05:01
  • Hall of Fame,
    2017 LAN, Wireless
Please console into the AP and post the bootup process.
albert.ho Sun, 06/27/2010 - 21:06
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 15 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 12751872
flashfs[0]: Bytes available: 19117056
flashfs[0]: flashfs fsck took 22 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 88:43:e1:28:4d:be
Loading "flash:/c1250-k9w8-mx.124-23c.JA/c1250-k9w8-mx.124-23c.JA"...#######################################################################################################################################################################################################
File "flash:/c1250-k9w8-mx.124-23c.JA/c1250-k9w8-mx.124-23c.JA" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-K9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 13:56 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 15 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31610880
flashfs[1]: Bytes used: 12751872
flashfs[1]: Bytes available: 18859008
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 0 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8363 8000 A8020000 0 A8030000 30
Radio1  present 8363 8000 B8020000 0 B8030000 13
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1252AG-C-K9   (PowerPC 8349) processor with 49142K/16384K bytes of memory.
Processor board ID FCW1319Z07X
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from unknown error PC 0x0
LWAPP image version 7.0.98.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 88:43:E1:28:4D:BE
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : A0
PCB Serial Number                    : FCW1319Z0KE
Top Assembly Part Number             : 800-29039-03
Top Assembly Serial Number           : FCW1319Z07X
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252AG-C-K9
% Please define a domain-name first.#
Press RETURN to get started!
*Mar  1 00:00:08.291: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.175: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.735: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.763: %LWAPP-3-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar  1 00:00:09.763: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messages)
*Mar  1 00:00:09.775:  status of voice_diag_test from WLC is false
*Mar  1 00:00:10.711: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.687: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.687: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:12.739: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.751: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:13.043: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:13.043: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:14.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:14.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:17.803: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio0, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:00:20.611: %SMC-2-BAD_ID_HW: Failed Identification Test in 0/0/0 [7/0]
       The module in 0/0/0 in this router may not be a genuine
       Cisco product.  Cisco warranties and support programs only
       apply to genuine Cisco products.  If Cisco determines that
       your insertion of non-Cisco memory, WIC cards, AIM cards,
       Network Modules, SPA cards, GBICs or other modules into a
       Cisco product is the cause of a support issue, Cisco may
       deny support under your warranty or under a Cisco support
       program such as SmartNet.
*Mar  1 00:00:20.747: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:00:20.899: %SSH-5-ENABLED: SSH 2.0 has been enabled#
abersven Mon, 06/28/2010 - 10:26
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
You have an issue with one of your radios in the 1250. Where did you get the module in 0/0/0? If that’s from Cisco you might need an RMA.
Try to pull out module 0/0/0 and try again without it.
André
jlhainy Tue, 10/26/2010 - 09:26
I am having a similar issue, only the AP is an 1142 and it is able to join the controller.
In the AP log I get *Oct 25 12:19:04.878: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag.
The AP joins the controller and Radio0 (2.4 ghz) comes online and everything is great.  However, the 5ghz radio seems to be having an issue.  The unusual thing is that the WLC says that this AP only has one Radio.  It doesn't show Radio1 as administratively up and operationally down, it just shows that Radio1 doesn't exist.
However, WCS knows that the AP should have Radio1 so it's giving me the alert.
Is this also a hardware issue?
Scott Fella Wed, 10/27/2010 - 19:52
  • Hall of Fame,
    2017 Wireless
I would try to convert is back to IOS and then see if the radios come up.  You can also run the show controllers dot11Radio command to see if the radio is functioning or not.
Related Content
