Differences between 3750-X and 3560-X
Jun 25th, 2010
Hi guys,
I need a switch with 10 GbE sfp+ uplink, base ip services and q-in-q support. I think 3750-X or 3560-X are the best and the cheapest choice. Am I correct? Or there is another solution?
I also wonder what are the differences between the two models?
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Fri, 06/25/2010 - 02:00
Hi guys,
I think yes you can go with any of the switch model as both support 10gb with feature of both the switch along with difference with other switches.
http://conft.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html#wp48759
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
martos1981 Fri, 06/25/2010 - 02:30
Thank you for the answer. It was helpful:)
As I understood - the only difference is the stacking option which 3750-x has...and of course - the price:)
