HELP upgrade fwsm procedure
Answered Question
Jun 25th, 2010
i need help for upgrade ASDM and Software of a FWSM.
My running software is FWSM Version 3.2(5) and i want to upgrade to last release.
ALso i want to upgrade ASDM to last release ASDM 6.2F.
Can some one explain me the exact procedure to upgrade the FWSM.
thanks a lot.
Correct Answer by Marcin Latosiewicz about 6 years 7 months ago
Yes, sir. That's correct.
You can store images for both ASDM and FWSM on disk if you want to, but you cannot boot them from disk.
Overall Rating: 5 (1 ratings)
f.mottini Fri, 06/25/2010 - 02:37
Thanks a lot,
the section that i must read is "Installing Application Software from the FWSM CLI" , correct?
But in ASA you download the image in DISK0:,here in the flashcard?
In ASA you must use command boot to specify witch ASDM or Software you want to load on boot, here i not specify nothing?
thanks a lot best regards.
Marcin Latosiewicz Fri, 06/25/2010 - 03:53
FWSM unlike ASA does not have the "boot system ..." CLI.
It can only boot from flash:image
Marcin
f.mottini Fri, 06/25/2010 - 03:54
So i need only to download the asdm and software version to falsh and that it......
correct ?
Thanks a lot.
Correct Answer
Marcin Latosiewicz Fri, 06/25/2010 - 03:57
Related Content
