NAT Rules
Jun 25th, 2010
Hi all,
At present I'm installing a ASA firewall between my 2811 router and the network.
The router at the moment has an internal ip address of 192.9.200.253 and has NAT rules set up. The 192.9.200.254 address is that of our exchange server. My question is this. If I change the internal interface of the router to 10.10.10.10 and the external interface of the ASA to 10.10.10.11 and the internal interface of the ASA has the 192.9.200.253 address, what do I do about the NAT rules?
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
ip nat inside source static tcp 192.9.200.254 25 *.*.*.*25 route-map Deny-VPN extendable
ip nat inside source static tcp 192.9.200.254 80 *.*.*.* 80 route-map Deny-VPN extendable
ip nat inside source static tcp 192.9.200.254 143 *.*.*.* 143 route-map Deny-VPN extendable
ip access-list extended Deny-VPN
permit ip 192.9.200.0 0.0.1.255 6.0.0.0 0.0.255.255
access-list 105 remark SDM_ACL Category=2
access-list 105 remark IPSec Rule
access-list 105 deny   ip 192.9.200.0 0.0.0.255 6.0.0.0 0.0.255.255
access-list 105 deny   ip 192.9.200.0 0.0.1.255 172.31.0.0 0.0.255.255
access-list 105 permit ip 192.9.200.0 0.0.0.255 any
route-map Deny-VPN deny 10
match ip address Deny-VPN
route-map SDM_RMAP_1 permit 1
match ip address 105
I've attached the complete config below
Egg
Jennifer Halim Fri, 06/25/2010 - 06:05
  • Cisco Employee,
You are just changing the interface of the router from 192.9.200.253 to 10.10.10.10, as far as the NAT statement is concern, you do not need to change anything. All you need to do on the router is to configure route for 192.9.200.0/24 subnet to point towards the ASA external ip address (10.10.10.11).
Assuming you are having the following topology:
Internal network (192.9.200.0/24) -- (Inside) ASA (Outside) -- (Inside) router (Outside) -- Internet
On the ASA, you would need to configure NAT exemption, or a static statement to itself.
Example:
static (inside,outside) 192.9.200.0 192.9.200.0 netmask 255.255.255.0
OR/ alternatively
access-list nonat permit ip 192.9.200.0 255.255.255.0 any
nat (inside) 0 access-list nonat
Hope that helps.
