NAT Rules
Jun 25th, 2010
Hi all,
At present I'm installing a ASA firewall between my 2811 router and the network.
The router at the moment has an internal ip address of and has NAT rules set up. The address is that of our exchange server. My question is this. If I change the internal interface of the router to and the external interface of the ASA to and the internal interface of the ASA has the address, what do I do about the NAT rules?
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
ip nat inside source static tcp 25 *.*.*.*25 route-map Deny-VPN extendable
ip nat inside source static tcp 80 *.*.*.* 80 route-map Deny-VPN extendable
ip nat inside source static tcp 143 *.*.*.* 143 route-map Deny-VPN extendable
ip access-list extended Deny-VPN
permit ip
access-list 105 remark SDM_ACL Category=2
access-list 105 remark IPSec Rule
access-list 105 deny   ip
access-list 105 permit ip any
route-map Deny-VPN deny 10
match ip address Deny-VPN
route-map SDM_RMAP_1 permit 1
match ip address 105
I've attached the complete config below
djh278778 Fri, 06/25/2010 - 16:35
I am not sure of your exact concern and the design here looks a little, "different" but hey, thats none of my business. Let me see if my assumption is correct. you have:   internet>2811>ASA>LAN. If this is correct you will continue to terminate the VPN on the 2811 but your not sure if these NAT rules need to move to the ASA or not?   You can but you dont have to. If you leave the NAT statements how and where they are, the incoming requests (ports 25,80,143) will hit your public IP on the 2811 (which is not changing according to my assumption), NAT to, and as long as you have a route in the 2811 (, and the correct routes in the ASA (X.X.X.X X.X.X., all should work well. However, if you do it this way you cant be doing NAT on the ASA for this network ( There shouldnt be a problem with your internet NAT on the 2811 either because as long as you dont NAT on the ASA, packets will remain sourced from 192.9.200.x when they arrive at the 2811 and hence be processed by NAT in the 2811. If you have to NAT in the ASA then include this subnet in your  "no nat (nat0)" statements.
Hope this helps.
