David Hailey Mon, 06/28/2010 - 08:02
  • Purple, 4500 points or more
The purpose of a PRI in the voice world is it serves as to provide PSTN connectivity from a Telco provider (Verizon, ATT, etc) to your organization's voice network via connection into a voice gateway that is registered to your voice infrastructure.
http://en.wikipedia.org/wiki/Primary_rate_interface
Hailey
Please rate helpful posts!
Lim Seow Hua Wed, 06/30/2010 - 02:22
How do we show the PRI port in the voice gateway by using command line?
Aaron Harrison Wed, 06/30/2010 - 03:19
  • Community Spotlight Award,
    Member's Choice, May 2015
You would use several commands:
show controllers e1
or
show controllers t1
(depending on card type)
And:
show isdn status
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
