WiSM 7.0.98 experiences?
zhenningx
Level 4
Level 4
Hello, I am checking what are people's experiences about wism 7.0.98? We want to upgrade to it to support clean air APs but two severity 2 bugs are holding me back:
CSCtg23618
WiSM is unreachable outside of Catalyst 6500 Series Switch.
CSCtg92171
The WLC stops responding to the network.
Thanks for all responses!
Zhenning
abersven
Version 7 is good. Some issues as you mentioned but it might be unlikely that these two bugs are relevant for you since there are not many that have seen these issues. But there is no warranty that you don’t hit a bug or find a new.
How is your topology? Do you have the controller and the access points in the same subnet?
/André
Hi Andrew,
Thank you for the response. We don't have controller and APs in the same subnet.
Zhenning
Good
Then you should try v7 and Clean Air. Remember that you need the AP 3500i or 3500e in order to run Clean Air.
/André
