CuciMoc 8.01 meetingplace error
Jun 25th, 2010
We are in the process of deploying CuciMoc 8.01 but we do not utilize Meetingplace.
At the current time pilot users are complaining about the Server Error on the bottom right hand corner for Meetingplace.
Since we are not using this feature is their any way to suppress this error?
Thank You
james.koniecki@... Fri, 06/25/2010 - 08:48
Thanks for the reply Mike this was included in the initial push.
I have tried deleting the WebConf strings
REM *** WEB CONFERENCING
SET WebConfPort="80"
SET WebConfProtocol="HTTP"
SET WebConfServer="meetingplace.mydomain.net"
SET WebConfServerValidation="1"
Pushed File >
REM *** VOICE MAIL MAILSTORE
SET VVM_Mailstore_Server_0="172.16.2x"
SET VVM_Mailstore_Server_1="172.16.2x"
SET VVM_Mailstore_ImapProtocol_0="TCP"
SET VVM_Mailstore_ImapProtocol_1="TCP"
SET VVM_Mailstore_ImapPort_0="143"
SET VVM_Mailstore_ImapPort_1="143"
SET VVM_Mailstore_InboxFolderName="INBOX"
SET VVM_Mailstore_TrashFolderName="Deleted Items"
SET VVM_Mailstore_EncryptedConnection="false"
SET VVM_Mailstore_PollingInterval="60"
SET VVM_Mailstore_DualFolder="true"
SET VVM_Mailstore_IdleEnabled="true"
SET VVM_Mailstore_IdleExpireTimeInMin="29"
REM *** Service Credentials Sources : Valid source are "", "PHONE",  "CONTACT", "VOICEMAIL", "WEBCONF"
SET VoiceMailService_UseCredentialsFrom=""
SET PhoneService_UseCredentialsFrom=""
SET ContactService_UseCredentialsFrom=""
set WebConfService_UseCredentialsFrom=""
REM *** CCMCIP Servers
SET CCMCIP1="172.16.2x"
SET CCMCIP2="172.16.2x"
SET CCMCIP_Server_Validation="0"
REM *** Video Options Visibility Setting
SET SetVideoEnablePref="true"
SET SetVideoStaticThrottlingPref="false"
htluo Fri, 06/25/2010 - 08:54
You should push this:
SET WebConfPort=""
SET  WebConfProtocol=""
SET WebConfServer=""
SET  WebConfServerValidation=""
This will make CUCIMOC aware that "web conferencing" was not configured, thus will not trigger the alert.
Ideally, you shouldn't push those entries at all.  (ie. remove those entries from registry).
Remeber, you'll have to kill the "cucsf.exe" in task manager to refresh the configuration.
Michael
