MTU Limitation on Gig Interface
Answered Question
Jun 25th, 2010
I read that the PA-GE module on the 7200 supports an mtu of >1500.  I'm trying to set mine to 1546, but cannot.  What command do I enter to enable support for this size?
EDR01#config t
Enter configuration commands, one per line.  End with CNTL/Z.
EDR01(config)#int gig 5/0
EDR01(config-if)#ip mtu 1546
% Invalid input detected at '^' marker.
EDR01 (config-if)#ip mtu ?
  <68-1500>  MTU (bytes)
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello David,
it is also a question of IOS image
also you need first to increase mtu with mtu command then you may be able to increase ip mtu
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 06/25/2010 - 07:26
  • Hall of Fame,
    Founding Member
Hello David,
Hope to help
Giuseppe
davidhvoss Fri, 06/25/2010 - 08:25
Version 12.4 (12.2r) T
Cisco 7200
Card is PA-GE (trying to change Gig 5/0 on this card)
