Audible voicemail alert for 7921?
Answered Question
Jun 25th, 2010
Does anyone know if there is a way to implement an audible alert when a new voicemail arives on a 7921? CUCM 6.1.
Correct Answer by Jaime Valencia about 6 years 7 months ago
There used to be a feature request for this but it didn't go any further:
CSCsj61447    Request to support audible and vibrate alert for MWI
Unfortunately it's not possible at this time.
You might want to reach your account team to submit a new PER or try to follow up on the above enhancement.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 06/25/2010 - 11:42
java
