Show and Share Flash Server??
Jun 25th, 2010
I was recording a video with my web cam and then tried to publish it. It appears in the lists of videos but I does not play.
1. I found that when you record a video from a webcam it automatically goes to the web server in .flv format.
2. I take the complete path URL to publish the video, since it does not run directly from the SnS.
I was reading in the users guide that Cisco suggests one server for each format if possible, so I checked out both of the servers suggested for Flash which are:
Wowza Media Server Pro 1.7.2
Adobe Flash Media Server
I have one web server and since I am using it just for demos. So I wonder if anyways I must have one of these servers running in the current web server or I need to deploy a separate flash server, or there could be something wrong and I should be able to run flash videos from the current web server without any modifications?
Note: I recall that in previous 5.1 version I used .swf for previews and that I could save them in the same web server and get them play from there.
I attached screen shots from my deployment locations in case they are helpful. I have to say that I am not an expert on managing servers but I could deploy an IIS just for this demo environment and it is working fine except for this flash issue.
Overall Rating: 3 (1 ratings)
Tomas De Leon Fri, 06/25/2010 - 10:35
You deployment settings for Flash look fine and passes the test.
After recording and publishing your WEBCAM recording, the SnS should
deploy to your web server in the location you setup.
On the Web server in the directory that you configured for Flash should
be a webcam.flv file.
ie. A-a4951e44-d4d1-48f8-aa88-4b36bb607a28-1273849267445WebCamCapture.flv
You should be able to download on your Client and or run directly on the
server with a FLASH Player.  The Correct FLASH format is "FLV".
Verify that you have permissions to run & execute files on your web server
for that directory and file.
Record another small web cam recording and than upload it here
so that I can look at the file and media information.
rguzman.plannet Fri, 06/25/2010 - 11:15
Here are the images of the new capture.
You should know that once I stopped the capture and the file was put into the server I could access the server via ftp and I could from my laptop play the file with GOM Player.
And after I typed the URL to publish the video from the server I could not play the file via ftp anymore.
Tomas De Leon Fri, 06/25/2010 - 12:56
Your problem is that you are changing the URL.  The URL is SELF created by the SnS when you save it.
DO NOT change the URL for a WEBCAM recording.  It does it on it own once it is published.
Try it again and DON'T change the URL.  Just Save & Publish...
rguzman.plannet Fri, 06/25/2010 - 13:19
I tried again:
1. It does capture de video and creates a file in the server.
2. I click publish and it does.
3. It appears in my videos.
4. Click play but it does not, I don't see any activity in my web server meanwhile.
More pics attached...
Tomas De Leon Fri, 06/25/2010 - 13:41
What browser are you using?
Have you tried different browsers and try to access
from another client?
Please go to the ADMIN Module on the DMM and look at
the Services TAB then the Show and Server.
Is the Streaming Server running on the Server?
My guess that it is NOT... because look at your
do not play image.  the little box does NOT have a
play arrow.
You will need to go to the Show and Share AAI interface
and restart the streaming server
Appliance Control-->Restart Options--> Restart_Streaming_Server
That should fix it..
rguzman.plannet Fri, 06/25/2010 - 14:24
This is driving my crazy lol now I can't record a video. I did what you suggested and then I tried to record a video and I got this error mesage.
I noticed that when I click record it the timmer doesn't run.
I tried with IE, Mozilla & Chrome, same problem for all.
Attached picture.
Tomas De Leon Fri, 06/25/2010 - 14:36
verify again that the streaming server is running...
create another recording and make sure you enter
all items for this test.
your snapshot is too high.. capture the entire screen when
you have issues
rguzman.plannet Fri, 06/25/2010 - 15:24
I can't get it run and I think that my problem as I said at the begining of this post, that I don't have a flash server installed. Therefore I cannot make any modifications nor create any webcam recordings.
I attached a document that explains this and if you did not know about this I hope it works for you, and if you did and I did not explain my self correctly "an apology" lol.
Thanks a lot for the time.
Tomas De Leon Fri, 06/25/2010 - 16:39
The Streaming Server "is" the Flash Server that comes with
the Show and Share appliance.  Editing your Web Cam Videos, Flash, and H264
videos can be done with the included streaming services server on the
Once the Video file is created, you can edit it by managing the video.
The documentation should elaborate on this...
rguzman.plannet Wed, 06/30/2010 - 15:14
Hi Tom,
I am still struggling with this issue.
I'll describe again the steps:
In My Show and Share go to Add Video/ Record a Video/ Camera and Microphone prompt click Allow/ Start Capture/ Pause Capture/ Save to Drafts/ It appears in My Videos with 5 buttons below the preview "Play, Manage Video, Edit Video, Publish, Delete"/ Click Play (works "This is a preview of your video"/ Go back to My Show and Share/ Click Publish/ Go to Videos/ Click Publish/ Go to My Videos/ Click Play... But nothing happens!
If you have any other suggestions they're more than welcome.
I followed up the steps from the document and I can't make it works.
I don't wether it is allowed or not through this Support Community to have WebEx sessions. If so please let me know I have a WebEx account.
Best Regards!
Related Content
