Cannot Delete Unity Subscriber
Answered Question
Jun 25th, 2010
I am trying to delete a Subscriber from Unity 5.0(1).  When I do so, I get the error "Delete Failed 0x8004010F".  There is nothing else that I can see that seems to be wrong.  Suggestions?
Correct Answer by David Hailey about 6 years 9 months ago
Paul,
Could be various things.  If you're in the position I think you are where you just want to delete the object, try Bulk Subscriber Delete from Unity Tools Depot.
Hailey
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 06/25/2010 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    2011
Try this:
SA page> subscriber > messages page of the subscriber uncheck the option to use MWI notification
Then try to delete again
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer
David Hailey Fri, 06/25/2010 - 10:57
  • Purple, 4500 points or more
Paul,
Hailey
