Warning message
ip address with port information
Jun 25th, 2010
I am trying to see
what ports with the IP address its connected to
I ran show ip int brief but can see only VLAN 1
i have 3 vlans on this 3560 Switch
any help would be appreciated.
Asif
I used:
sh mac-address-table address ??-??-??-??-??-??
or just
Vlan    Mac Address       Type        Ports
666  XXXX.XXXX.XXXX    DYNAMIC     Po6
In your case it will show the port, i am aggragating a bunch of switchs that's why it show my port channel.
Hope that helped
Reza Sharifi Fri, 06/25/2010 - 14:15
  • Cisco Designated VIP,
    2017 LAN
In addition to Adam's comment, you can do a "sh ip arp" to see the IP and MAC address of the connected device and then do a "sh mac-address-table" to see what port that IP/MAC is connected to.
Reza
Ganesh Hariharan Sat, 06/26/2010 - 22:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
I am trying to see
Asif
Asif,
As suggested by others try also with command show ip arp and show arp to find the details of the ip and mac with port details.
Hope to Help !!
Ganesh.H
akhanwaterloo Tue, 06/29/2010 - 06:06
Thanks all
When this command is executed
show ip arp
only default vlan1 connected evices shows up
i have two other vlans data and voice they do not show the devices connected
How can i see the devices connected to these two vlans
Asif
