How to set RAID 1 in C200-M1
Answered Question
Jun 25th, 2010
Hi, does anybody know how to set RAID1 in UCS C200-M1?
Thanks in advance
Lenin
Correct Answer by jdrurycisco about 6 years 9 months ago
Go into the BIOS of the server and disable quiet boot.  Once this is done reboot the server and enter the LSI config during the boot process.  I think it is a ctrl-S to get into the LSI config.  Once you are in the LSI config you can set the RAID level for the drives.
Overall Rating: 5 (1 ratings)
leninvs2502 Sat, 06/26/2010 - 14:27
Thanks for replying ccietrainee1, I've got a C200-M1 with two local disks, 140GB each one, and I want to set RAID 1 between them, how can I see the type of RAID controller in the server or do I have to install it?
I really appreciate your help
Correct Answer
jdrurycisco Sat, 06/26/2010 - 16:30
leninvs2502 Sat, 06/26/2010 - 17:23
Thanks a lot jdrurycisco,
I'm using ESX 4.0 Update1, Do I have to reinstall it after change to RAID 1 or it's not necessary?
Very grateful
Lenin
Related Content
