Recovery Password Pix 506e???
Jun 25th, 2010
I have a trouble with a pix 506e, we lost the password and I need recovery it. I was reading the procedure that there is in the web site cisco and not work,
My problem is when I send a ping from pix to my pc no problem it work, but if I send a ping from my pc to pix it don´t work. I have disabled firewall, Antivirus, or any one other program that drop the comunication.
So I can't recovery the password.
Can you helpme???
Federico Coto F... Fri, 06/25/2010 - 17:26
Even if you disabled firewalls, antivirus, etc.. most likely something in the machine is messing around.
Have you tried from a different computer?
hmonroy2012 Sat, 06/26/2010 - 11:02
Yes, I did tests with other computer. but still the same problem.
Thank you
