WAAS Deployment
Jun 25th, 2010
I have 2 sites, in the first is the Data Center and in the other is a small Branch (25 user). I want to install WAAS, in the DC a WAVE-474 (accelerator mode) and WAVE-274 (Central Manager Mode) and in the small Branch a WAVE-474.
I found in a document that the WAVE-474 doesn´t have capacity to fan-out.
Is this scenario possible?
thanks,
Zach Seils Mon, 06/28/2010 - 06:02
  • Cisco Employee,
For only two (2) sites this configuration is fine.
Do you plan on expanding the deployment size in the future?  If so, how many remote sites will you need to support?
Zach
Rene Melendez C... Mon, 06/28/2010 - 07:07
The idea is to start with 2 sites (the core and remote site), then when we have to add a new remote site, then the WAVE-474 will be sent to the new remote site and in the Core would use a WAVE-574 or WAE-512.
RMC
Zach Seils Mon, 06/28/2010 - 09:38
  • Cisco Employee,
Sounds like a good plan.  The device models you are planning to use will be fine.
Zach
