Configuring two 128 Kbps ISDNL line one 256 Kbps ISDN Line
Answered Question
Jun 26th, 2010
I want to connect 3 branches with ISDN line . All the branches bandwidth requirement is 256 Kbps . As I have suggested the combining 2 ISDN line in to 1 ISDN line by Multilink Group. I have confussion over the configuration .
interface BRI2/0
encapsulation ppp
dialer rotary-group 1
isdn spid1 0835866201
isdn spid2 0835866401
interface BRI2/1
encapsulation ppp
isdn spid1 0835867201
isdn spid2 0835967401
interface Dialer1
ip unnumbered Ethernet0/0
encapsulation ppp
dialer in-band
dialer map ip 172.20.2.1 name kdt-nas 8358661
dialer load-threshold 100 either
dialer-group 1
ppp authentication chap callin
ppp multilink
// I don't have the SPID no , I have the ISDN No should i add the country code as well before the We DN no or how it will be in case only ISDN no .  Our ISDN no is 968-24609638 , 639 . Kindl assist me to configure the ISDN .
Correct Answer by spremkumar about 7 years 3 weeks ago
hi
i guess its a point to point ISDN line between your locations, as far as i know you dont need to have SPID instead you can configure the remote peer isdn no.
below link provides you a simple sample config which you can try out there..
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a00800a3b7a.shtml
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Mon, 06/28/2010 - 06:59
  • Red, 2250 points or more
hi
regds
ashraf.kazi Tue, 06/29/2010 - 01:47
Thanks Prem  this is the exact scenario
Rgd's
Sayed Ashraf
