ASA 5520 VPN
Answered Question
Jun 26th, 2010
Seeking help on whether it is possible to concurrently have both SSL & ipsec/site-to-site vpn configured on a 5520. If so, would there be any performance degradation or any limitation on no. of users being permitted.
Any other things, which i need to know in this regards.
Appreciate all your help,
Thanks.
Correct Answer by Jennifer Halim about 7 years 16 hours ago
Yes, you can have SSL VPN, IPSec Site-to-site as well as IPSec remote access VPN configured and running concurrently.
Here is the what ASA5520 can support:
- 750 IPSec (inc. Site-to-Site and remote access VPN)
- 750 SSL VPN
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Please kindly be advised that for SSL VPN, it only comes with 2 default license, and you would need to purchase the SSL license if you are going to run more than 2 SSL VPN sessions concurrently.
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Sat, 06/26/2010 - 23:01
  • Cisco Employee,
- 750 SSL VPN
Hope that helps.
