Contact Center
I have script with toll free number(sip) the caller sometimes hear all audio prompts in menu, and sometime hear some audio prompts which not stable, but when I dial internally the trigger it is stable and I can hear all audio prompts in menu, What co...
matee by Level 1
  • 221 Views
  • 2 replies
Hi All,I wonder if any of you have increased the vRAM on your UCCE Rogers/Aw-HDS beyond the prescribed by OVA numbers? I.e. if Rogger is said to have 6GB by the OVA can I make it 8?  SQL is eating memory plus there is some other management and securi...
Engnr by Level 1
  • 123 Views
  • 2 replies
Hi, We have some scripts that send a call redirect to a user's voicemail greeting and this works fine, using the call redirect step (destination = VM pilot, Called address reset to user's Ext.).The current set up from CUCM to Unity is SCCP, and I've ...
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 171 Views
  • 3 replies
Greetings, Can you provide the URL and Body example to update a campaign via the Outbound API.  I am able to Create Campaign, Get Campaign Definition, Get Campaign Records, Import Campaign Records, Delete Campaign Records, and Delete Campaign, but th...
galguire by Level 4
  • 1012 Views
  • 5 replies
A customer reports that contact center agents sometimes get a 403 Forbidden when trying to log into the desktop. This error resolves itself on its own after around a few hours; without going deep into troubleshooting, can someone give me a few hints ...
pescla by Spotlight
  • 93 Views
  • 2 replies
