How can we Deploy Custom "Say It Smart" Plugin ?
Jun 26th, 2010
I have created a Say It Smart plugin Java class HijraSayItSmart extends SayItSmartBase implements SayItSmartPlugin.
I want to use this Plugin in my CVP Projects.
I have gone throught the Programmers Guide for this.
I tried by copying the class file to:
   1. callstudio/eclipse/plugins/
   2. deploy/java/application/classes
But this is still not available in the Audio Element Types of my Project.
Is there any other big or small steps to do before it gets available.
Please give the detailed step to realize this.
I am a beginner in this regard.
I looked at your code (nice comments) and you have started with the correct template, and all the functions appear to be there. common\classes is the normal place to put custom Action Elements, and I believe that is also the correct place for your custom SayItSmart.class file.
The line
SayItSmartDisplay toReturn = new SayItSmartDisplay("hijra", "Hijra Month", description);
should mean that you could add an Audio Element, choose SayItSmart, and find your plugin in the dropdown box.
