Cisco Network Assistant 5.5
Answered Question
Jun 27th, 2010
I  downloaded Cisco Network Assistant 5.5, everytime when I try to run I get error message "Could not creat Java virtual Machine' any idea how to solve this?
Correct Answer by Ganesh Hariharan about 6 years 6 months ago
to solve this?
To overcome this problem, open the file C:\Program Files\Cisco Systems\CiscoSMB\Cisco Network Assistant\startup\startup.properties (the default installation path), and modify this entry:
JVM_MAXIMUM_HEAP=1024m
Replace 1024m with a lower setting that does not exceed the available RAM. There is no way to foresee what value will work. Try 512m, and lower it further if necessary. You can use the dial peer tag range 2500 to 2999 out-of-band to define your own dial peers.
Check out the below link for more information
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Sun, 06/27/2010 - 22:39
to solve this?
Hope to Help !!
Ganesh.H
