RV016 Bandwidth Management and VOIP Quality Issues
Jun 27th, 2010
I replaced an old router with a Linksys RV016 at a small office comprising about 15 computers and 15 VOIP Phones (using G729a requiring ~80kbps). I am hearing complaints about the following
1) Incoming VOIP Quality is bad, Outgoing is fine.
2) Downloads to computers are slower than before.
I am a bit new to VOIP but have some solid networking experience. However I am concerned I do not fully understand the bandwidth management of this device and I think the Linksys documentation is a little light.
Should I be using priority instead of rate control?
Are the MIN/MAX rate control figures shared among the IP addresses or are they applied to each? I have adjusted these rates up and down without any improvement (although I haven't been back to test myself).
Below are the settings for the router. If anyone has any suggestions I would appreciate the input.
ISP Speed: 3 M Up/Dn
Router: Linksys RV016
WAN1: 10M Full (per ISP Modem)
DHCP Enabled: .150-199 (for Computers)
DHCP Resrved: .101-149 (for VOIP Devices)
Bandwidth Management: Rate Control
All TCP/UDP Traffic~
(Also used min max of 1024, 1548)
Firewall Enabled:
VOIP1~UDP~5060- 5090 (As per VOIP provider)
VOIP2~UDP~16384-16482 (As per VOIP provider)
VPN: PPTP Server
(only used by me for adjusting configuration remotely)
alex.mortlock Mon, 10/25/2010 - 10:10
i myself am having issues with an RV082. V2 running (only new firmware)
the bad call quality is packets droping from your voip trunk.
i have yet to find a way to get the bandwidth rate control to work on
incoming data. uploads are limited just fine. as for the is this
a group limit or a single client limit level i  have assumed that it is a
per ip limit which does not help bottlenecking of the wan connection.
davbarre Wed, 10/27/2010 - 12:48
Hi Justin,
Do you happen to have SPI (Stateful Packet Inspection) Enabled on the Firewall?
