Cisco 1252 downgrade from Lightweight to Autonomous
Jun 27th, 2010
one of my customers has 60 of 1252 access-points running lightweight with 4404 Controllers, he is  asking if there is such way to downgrade these access points through  the controller instead of manual one by one way ?
If yes please how ?
abersven Sun, 06/27/2010 - 15:50
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I have one suggestion on how you can do this. But you need to do some work in a text editor to compile a list of the access points and convert each line in that text file so it have the command to convert the AP from lightweight to autonomous. Excel might be a tool you can use to make the list.
I have an example from my controller on how you can do this assuming you want to use the software c1250-k9w7-tar.124-21a.JA1.tar.
You need a TFTP server with the image you want to use. In my example the address of the TFTP server is
Make a list and past it in and you will see that the APs are starting to download the image from your TFTP server. After you reboot them they are autonomous.
List your APs and copy the first column with the AP names:
(Cisco Controller) >show ap summary
Number of APs.................................... 2
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
AP01-Livingroom      2     AIR-LAP1252AG-E-K9     00:23:04:b8:f5:ce         MV21B, LR  1        NO       1
AP02-BlueRoom        2     AIR-LAP1252AG-E-K9    00:24:14:4f:53:06       Radio Shack  1        NO       1
Command for downgrading an AP to the software image you prefere:
(Cisco Controller) >config ap tftp-downgrade c1250-k9w7-tar.124-21a.JA1.tar AP01-Livingroom
Example list you can paste in:
config ap tftp-downgrade c1250-k9w7-tar.124-21a.JA1.tar AP02-BlueRoom
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
