06-27-2010 02:46 PM - edited 03-04-2019 08:54 AM
Hello all,
FW-----OSPF--->L3switch----redistribute--OSPF into EIGRP ----->WAN router---->dist BGP
The firewall is advertising 10.10.10.1/32 to my l3 switch via ospf, then I want to redistribute that route to my wan router via eigrp 1. WAN router is not seeing the route, if I do a "show ip eigrp top | i 10. in my l3 switch I get the following"
P 10.10.10.2/32, 0 successors, FD is Inaccessible
show ip roure ospf
O E1 10.10.10.2 [110/2] via firewall, 05:32:36, Vlanxx
router eigrp 1
redistribute static
redistribute eigrp 2 metric 128 23000 255 1 1500 route-map WDSin
redistribute ospf 1 metric 100 1 255 1 1500 route-map DMZin
I don't understand why my l3 switch is showing FD inaccessible and not redistributing the route to my wan router.
Thank you very much in advance for any imput.....
Cheers!
Solved! Go to Solution.
06-27-2010 04:24 PM
The 10.10.10.2 is known by OSPF which has an admin of 110 once it is redistributed in to EIGRP it becomes on external EIGRP route which has an admin distance of 170. So the route is still known by OSPF since it has a lower AD. Try manipulating EIGRP external admin distance to some thing lower the 110 and test again.
Reza
06-27-2010 04:41 PM
It could be that the DMZin route-map is filtering this route. Could you post its configuration and check please?
Marcel
06-27-2010 04:24 PM
Reza
06-27-2010 04:41 PM
Marcel
06-27-2010 10:35 PM
Hello Mguzman4158,
the firewall injects an OSPF O E1 external route in OSPF domain not an internal route.
In order to redistribute it from OSPF into EIGRP you need to specify route-type external1 in the redistribution command
By default only internal OSPF routes ( O or O IA ) are redistributed into another protocol
Hope to help
Giuseppe
06-27-2010 11:25 PM
It looks like there are two things going on here:
1. 10.10.10.2/32 shows up with an FD inaccessible on your L3 switch
2. 10.10.10.2/32 is not received on your wan router
These could have different root causes.
I have recreated the topology you presented and tested the following:
R1-s1/0-[OSPF]-s1/0-R2-s1/1-[EIGRP]-s1/0-R3
R2 is receiving an ospf e1 route of 10.10.10.10/32 from R1 and redistributing it into EIGRP towards R3:
R2#sh ip ro ospf
10.0.0.0/32 is subnetted, 1 subnets
O E1 10.10.10.10 [110/2] via 172.16.12.1, 00:00:08, Serial1/0
R2#
R2#sh ip ro 10.10.10.10
Routing entry for 10.10.10.10/32
Known via "ospf 1", distance 110, metric 2, type extern 1
Redistributing via eigrp 1
Advertised by eigrp 1 metric 100 1 255 1 1500 route-map DMZin
Last update from 172.16.12.1 on Serial1/0, 00:04:01 ago
Routing Descriptor Blocks:
* 172.16.12.1, from 1.1.1.1, 00:04:01 ago, via Serial1/0
Route metric is 2, traffic share count is 1
R2#sh ip eigrp topology 10.10.10.10 255.255.255.255
IP-EIGRP (AS 1): Topology entry for 10.10.10.10/32
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 25600256
172.16.12.1, from Redistributed, Send flag is 0x0
Composite metric is (25600256/0), Route is External
Vector metric:
Minimum bandwidth is 100 Kbit
Total delay is 10 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
Originating router is 2.2.2.2 (this system)
AS number of route is 1
External protocol is OSPF, external metric is 2
Administrator tag is 0 (0x00000000)
R2#
R3 receives the route as expected:
R3>sh ip ro 10.10.10.10
Known via "eigrp 1", distance 170, metric 26112256, type external
Last update from 172.16.23.2 on Serial1/0, 00:03:49 ago
* 172.16.23.2, from 172.16.23.2, 00:03:49 ago, via Serial1/0
Route metric is 26112256, traffic share count is 1
Total delay is 20010 microseconds, minimum bandwidth is 100 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
R3>
Message was edited by: Marcel Lammerse
