06-27-2010 03:09 PM - edited 03-10-2019 05:13 PM
Got information: "Manifest file not found in the bundle" by using command "patch install 5-1-0-44-1.tar.gpg ACS_Upgrade",
Any help? Thanks
06-27-2010 10:10 PM
The command for the upgrade is:
application upgrade application-bundle remote-repository-name
06-28-2010 04:29 AM
It's weired. My ACS5.1 has different command sets now.
At beginning, the command is same as document, after I tried with a non existing repository and select "no" at save configurartion, the command set changed. Is this a stupid bug? Will open a ticket this morning.
06-28-2010 04:41 AM
Same result use command "application upgrade":
ACS01/admin# application upgrade 5-1-0-44-1.tar.gpg ACS_Upgrade
Do you want to save the current configuration ? (yes/no) [yes] ?
Generating configuration...
Saved the running configuration to startup successfully
% Manifest file not found in the bundle
08-02-2010 08:59 AM
Hi Kevin Sun,
You forgotten to put the comand acs before the patch argument...
The correct is "acs patch install 5-1-0-44-1.tar.gpg ACS_Upgrade"
By the way, I recommend that you use the last patch avaliable, 5-1-0-44-3.tar.gpg
My Best Regards,
Andre Lomonaco
08-03-2010 02:46 AM
Hi Guys
I have a problem to download in the acs tha patch 5-1-0-44-3.tar.gpg:
when I try to do this I receive the browser message :"Failed to extract version from the patch bundle. Please verify that this patch bundle is valid".
I have an 1121 appliance with 5.1.0.44.2 version installed.
The Md5 checksum of the downloaded file is correct.
Can Anyone help me?
Thanks and Regards
08-03-2010 04:27 AM
Mak sure don't use tftp as download server, use ftp only. This was my problem, not command related.
08-03-2010 05:33 AM
Thanks a lot yuo have resolved my problem.
good job!!!
08-17-2010 10:43 AM
After beeting my head against the wall on this, I decided to put the patch file onto a box that did not have pkzip or power archive on it. Essentially so that this patch file would not associate itself to a program.
I then re-named it to 5-1-0-44-3.tar.gpg (it downloads from Cisco's web site as 5-1-0-44-3.tar.tar)
I then was then able to use FTP to apply the patch and do "acs patch install 5-1-44-3.tar.gpg (repository)
Seems as though the script only wants to see .gph ye for some strange reason the file downloads as .tar.tar
-pat
