How to send voicemail to HP number, and distribute to hunt group members?
Answered Question
Jun 27th, 2010
Hi..
I'm using CUCMBE 7.1.3 I have 6001 as HP number with 6002 & 6003 as Hunt list member. When I call to HP number (6001) and no body pick up the phone, it will redirect to voicemail.Voicemail Should be sent to ext 6002 & 6003. But only ext 6002 receive the Voice mail. I have configured 6003 as alternate ext. MWI in 6003 is on. I can't retrieve voicemail in 6003. How to send voicemail to HP number, and distribute to hunt group members?
Thanks..
Correct Answer by Aaron Harrison about 6 years 12 months ago
MWI isn't sent to alternate extensions by default.
Go to the subscriber in Unity admin, and go to the Messages page for that subscriber. At the bottom is an 'MWI Extensions' setting. X means 'the extension associated with the mailbox', so in this case you don't need that. Replace it with 6002, and add 6003...etc.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
riko.arizona Sun, 06/27/2010 - 21:00
Hi..
Now I can send voicemail to HP number and distribute to hunt group members. I'm using alternate ext. I can retrieve voicemail from ext 6002 & 6003. But the problem is MWI on 6003 is off. I can't get information if there is a new voicemail in ext 6003, because MWI on ext 6003 is off. In ext 6003, I can dial DN for MWI on or MWI off. From Service parameter configuration, I try to change Message waiting Lamp policy, but MWI is still off. How to make MWI is on while there is a new voicemail in ext 6003?
Thanks.
Correct Answer
Aaron Harrison Tue, 06/29/2010 - 01:43
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
