ACL processing in Cisco 3845
Ahmed Shahzad
I would like to know that ACL processing in Cisco 3845 is hardware based or software based?
May I have a list of hardware that support dedicated ASIC for ACL processing?
Thanks and Regards,
Ahmed Shahzad.
Ganesh Hariharan
Thanks and Regards,
Ahmed Shahzad.
Ahmed,
ACL processing is primarily accomplished in hardware, but requires forwarding of some traffic flows to the CPU for software processing. The forwarding rate for software-forwarded traffic is substantially less than for hardware-forwarded traffic. When traffic flows are both logged and forwarded, forwarding is done by hardware, but logging must be done by software. Because of the difference in packet handling capacity between hardware and software, if the sum of all flows being logged (both permitted flows and denied flows) is of great enough bandwidth, not all of the packets that are forwarded can be logged.
These factors can cause packets to be sent to the CPU:
•Using the log keyword
•Enabling ICMP unreachables
•Hardware reaching its capacity to store ACL configurations
If ACLs cause large numbers of packets to be sent to the CPU, the switch performance can be negatively affected.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Thanks Ganesh.
I am still concerned that Cisco 3845 have a dedicate ASIC for ACL processing? Also may I have a list of Routers support dedicated ASIC for ACL processing?
Best Regards,
Ahmed Shahzad.
